Old 17th October 2011, 10:03 PM
i would move the tops out on the fronts and use a shorter shock and spring
at the rear if you move the top out you may create a clearance issue with the rear wheel so you could modify the top suspension arm to take a bottom shock mount but i would be up rating it to take more load
hope that helps
