Old 19th October 2011, 07:55 AM
mopple mopple is offline
voucht,
have you contacted Janne E? He got his car recently registered in Sweden. Here's some pictures of his car http://www.haynes.co.uk/forums/showp...2&postcount=62. Looks to me that his front shocks are per book design.
Old 19th October 2011, 10:18 AM
Hi Madis,
I watched the pictures of his car last week (and I think it is beautiful) but no, I didn't know he was in Sweden. And you are right, the suspension seems to be according to the book. I send him a personal email right now.
Thank you for the tip !
Old 19th October 2011, 11:32 PM
In regards to the front suspension what if you were to go for inboard suspension as they are more vertical and would solve the issue.
Old 20th October 2011, 07:00 AM
Hi Ozzy,
Thank you for your comment.
Yes, might be an idea, but in that case, I have to check if the angle of the push-rods will not be THE issue. I also have to check if I have enough clearance between the radiator fan and the engine.
Old 20th October 2011, 12:32 PM
Tilly819 Tilly819 is offline
you could do a rocking upper arm design, like this
http://www.google.co.uk/imgres?q=roc...1t:429,r:7,s:0
tilly
www.heraldic-motorsport.co.uk
Old 20th October 2011, 03:29 PM
MarkB MarkB is offline
As long as there is sufficient travel in the shorter damper you should be fine.
Old 20th October 2011, 05:42 PM
Tilly, yes, it would be great, thank you for the link, but honestly, I want to keep the modifications as simple as possible, so I think I will go for an extension "box" as on the Robin Hood, as Phil advised (I'll post the design of the extension as soon as it is finished, to have your opinions about it)
According to my 3D simulations, I should be able to use 11'' coilovers front and rear. Which leads to an answer for MarkB : the stroke of a 11'' is 3'', do you think it is enough ? The 13'' have a 4'' stroke, so I'm loosing about 25mm of travel.
Thanks for your comments.
