Old 9th March 2007, 05:35 PM
Chris Gibbs
Default Indicator buzzer
Hi,
Leaving your indicator on is a real worry in an open car such as the Haynes Roadster, road and wind noise mean that you can’t hear the flasher unit. Here’s a simple circuit that gives you an audible warning a bit louder than the “tick tick” of the flasher unit.
The parts are available from Maplins
Piezo buzzer – part number FL40T
Diodes – part number QL73Q
No doubt electrical types will be able to come up with a better circuit, maybe incorporating a timer or some way of stopping the buzzer when the hazards are on? I could see that being very annoying!
Chris
Old 12th May 2007, 11:46 PM
scudracer scudracer is offline
Those cars-with-that-number have a piezo buzzer or something when the signals are on. Had a ride in one a couple of days ago ... I'm hooked!!
Old 22nd February 2014, 04:17 PM
axle's Avatar
axle axle is offline
Has any ones else fitted this, I have followed this wiring diagram it works fine when the engine is off, but when the engine is running you hear a faint noise of the buzzer.
What is wrong I am tempted to disconect it!
Originally Posted by Chris Gibbs View Post
Hi,
Chris
Regards Axle
Old 22nd February 2014, 07:39 PM
im thinking back feeding off of somthing
Old 22nd February 2014, 08:49 PM
Good idea - a buzzer
I have a relay thingy never fitted when I fitted a towbar.How would I wire it?
Old 22nd February 2014, 09:11 PM
im pritty sure it works on load so not much good unless you have a trailer unless your able splice it in some how?
Old 4th March 2014, 01:15 PM
For what little piezo buzzers cost it would be practical to have oine for each side.
