Old 24th October 2011, 02:31 PM
Hung my diff in the frame and painted it matt black, will be a rolling frame soon!
Old 24th October 2011, 02:32 PM
MikeB MikeB is offline
Roller,
Engine in and first start completed.
Next job, fuel lines and engine wiring.
Old 24th October 2011, 03:49 PM
had mine to rolling chassis stage then took it all apart to paint its now back with engine diff prop etc in floors foward trans tunnel panels and back panel are on steering rack / colulm in pedal box nearly finished. next task i think will be getting it back on 4 wheels then make a fuel tank.
im another one whos progress has slowed due to a baby
Old 24th October 2011, 04:27 PM
I have slowed due to not bing bothered.....
Will get myself back in gear soon.
Old 24th October 2011, 07:24 PM
Tilly819 Tilly819 is offline
finished and broken....
did enjoy driving it though lol
tilly
www.heraldic-motorsport.co.uk
Old 24th October 2011, 07:56 PM
Rolling chassis on dummy struts. Engine and gearbox in , diff and shafts in ,tank ready to install, loom plugged in and engine spins on the starter. However still have an earthing problem eg indicators work but not headlamps--probe shows as 3 +ves at the main headlamp bulb
also cant get a spark at the plugs or leads--is there an easy way to test if the coil is working??
Some advice here would be appreciated
ps I have snipped out irrelevant parts of the loom and removed the fuses.
ppsI realise Im about to change the subject of this thread so please reply under electrics-- sorry
http://s1189.photobucket.com/albums/z429/ayjay50/
Old 24th October 2011, 08:15 PM
shh120m's Avatar
shh120m shh120m is offline
just started to make an exhaust manifold cut the side panel in the wrong place
Old 24th October 2011, 08:20 PM
I saw somewhere probably ebay a guy selling paper or card templates for the roadster side panels. Not a bad idea when you hear how many people make a mistake on cutting these.
