Old 29th October 2011, 10:12 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I seem to remember a while back someone was talking about this and when they calculated the weight saving on the chassis alone it would have been about 25 percent lighter for the same stiffness but like twinturbo said hanging things off it may be a different matter I was thinking of just using round tube for the bracing parts did a search a while back for tube benders that you could make yourself and came across a contraption that uses the rear hub off a mk3 fiesta and a long length of bar dont know how well it would work but may be worth a try I will post a link when I get home tonight
Old 29th October 2011, 12:17 PM
TSM Locost's Avatar
I agree with you Talon, To make a car go faster, just add lightness. Colin Chapman.
Be Lucky, Mike.
Old 29th October 2011, 08:26 PM
MarkB MarkB is offline
Bent tubes are bad, short welded tubes are stronger. For an example look at a Ducati 916 frame.
Lighter cars are better than heavy cars as they don't hit things so hard, also don't need 200 pub talks to make it move...
Old 1st November 2011, 10:11 AM
vmax1974's Avatar
sorry i was slow in this been busy here is the link http://www.thefont.info/tubebender/tube_bender.htm
Old 4th November 2011, 03:50 PM
Tilly819 Tilly819 is offline
I wrote a program that compares tube and box sections for stifness in bending and torsion also restance to tension and compression and a comparison of weight. if you want direct comparisions between various tubes/box's let me now the sizes and i will enter the figures
hope this helps
tilly
www.heraldic-motorsport.co.uk
Old 16th November 2011, 03:34 AM
danilo danilo is offline
Do a wee bit of research and you will find that Lotus and Caterham use 16ga and 18 ga tubings.
Much lighter than the DIY crowd typically uses for their builds.
Apparently the demonstrable benefits of chassis designed by good Engineers
Old 16th November 2011, 11:11 AM
TQ_uk TQ_uk is offline
There's a section in this book:
about square/tube comparison - will see if I can remember to have a look tonight & paraphrase it.
Tilly, if you can put up tube 'equivalents' for the usual box section(s) used that'd be great e.g 25mm @ 1.6mm = ?, 25mm @ 2mm = ? etc. Though rest assured we won't hold you accountable
