Old 1st November 2011, 05:14 PM
i used the water trick when i cut & shut my ally zetec xr2i sump (no chalk).
i was going to use the sump from my doner cvh but as the zetec had a pickup at the front and i had a tig i converted that. set level with the bellhousing of a type9 i lost 0.5l too worked real well
Old 3rd November 2011, 12:10 PM
Further info about the 1.8 CVH sump on Zetec: the original gasket sits in a recessed channel in the cast ally sump, so it does not work with the steel sump. The CVH sump silicone gasket does not quite fit. The front arc of the gasket is 5 mm thick, whereares the gap is just ~2 mm. This prevents the gasket from sealing in the part of the flat sides. The arc around the rear crank seal seats OK. I'm going to cut out the front part of the gasket and fill the gap with silicone sealant.
Also, it turned out that I got the sump without reinforcing strips that go under the bolts. The thin sheet distorts under the bolts, event with just 6 Nm torque and with huge washers. I'll try to get the strips or make them myself out of 3 mm steel.
Old 3rd November 2011, 06:29 PM
Nice work on your sump Albert
I was sure that I had a pair of those reinforcing plates out in my workshop.
Had a very quick look earlier & can only find one of them, I am sure that I wouldn't have thrown the other one out.
Will have a better look tomorrow, if the other one turns up I would be happy to pop them in the post for you.
