Old 7th November 2011, 07:59 PM
The brackets on the front frame goes on the lower angled section, the top edge of the bracket sits on the weld between the two. If your too wide between hole centres it does'nt matter too much as there is adjustment in the drag link, you just need to split the difference between left and right.
