Old 24th November 2011, 09:03 PM
i take it we are on about that sprial formed stuff?
cant see a problem unless you have a cat. as it doesent form a 100% seal could throw up a airleak at the cat test.
if you need flex with a cat use a belows type with the protective woven steel wires over the top
can be found in clamp or weld in types
