Old 17th October 2008, 07:34 AM
bobbyh bobbyh is offline
Default Bmw 750
Good morning
my m8 has just brought another 750 to swich the engines over as he killed his lol
any way the resone i tell you this is becuse i'm going to try and use the dif (shortaned) and the brakes and other parts if you can sugest any. i my build should be a cheep parts bin the car cost him £450 so should get a good prce
Old 17th October 2008, 11:39 AM
Chris Gibbs
Hi Bobby,
The 7 series diffs are very big, I should have a measure before you buy it.
The driveshafts and brakes are also pretty big and the hubs are attached to the trailing arms (like the 3 series) - this means that you'll probably need to make new hub carrirers up to fit a similar upright to the sierra one.
Let us know how you get on.
Chris
Old 17th October 2008, 12:03 PM
right do you have any ideas on how to make the huds@?
Old 17th October 2008, 12:30 PM
Chris Gibbs
Internally you need to match the outer diameter of the wheel bearings. Eternally you need to be able to bolt or weld the bearing carrier to the upright in a similar way to the sierra hub.
I'll do you a little sketch later
Chris
Old 19th October 2008, 08:36 PM
Chris
thanks for the help
