![]() Quote:
Im in progress with this one. Currently bespoke building the chassis to take the SD1 engine and gearbox.... its very tight! (the gearbox tunnel needs redesigning if you want to use the SD1 box). I know there are lighter engine gearbox combinations but its a personal thing. Be interested in how your build / mod goes. Keep in touch Martyn |
![]() I am using the ford v8 not the rover , has the same install problems though. I have made up a flywheel using a diesel mitzi shogun ring gear <12" diameter> That takes a tvr twin plate clutch. Engine has a back plate with the mitzi reduction gear starter, that just leaves me to make or modify the getrag 265 bellhousing.or buy one of these http://t2.gstatic.com/images?q=tbn:A...ggQeyYo8wzX6Dw All this allows the lump to go back without altering the gear tunnel. Also the top of the cylinder heads are only 40mm above the top side rail of the chassis, there is also loads of room for the headers and steering column.Cant see the rover being much different other then its about 4" taller. Here is a v8 locost http://www.youtube.com/watch?v=ZhNUG3t3NRU and something scary http://www.youtube.com/watch?v=GqCnMahHGbk
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 12th December 2011 at 10:32 PM. |
![]() Quote:
Keep in touch with the build, maybe we can compare notes. Best regards, Martyn |
