Old 4th January 2012, 01:17 PM
I understand that but we weld galv pipe all the time and you wouldnt really tell the difference between that and normal steel when we(not me) weld it.Was just a point of view and suggestion and not meant to be derogatory.
Old 4th January 2012, 06:03 PM
Toyotus Toyotus is offline
Here's what I used for bushings, (a 4x4 post of nylon!) I cut a cross section at 1 3/16"(30mm) then took "core samples" with 1" (25mm) hole saw
I can't find a collar/sleeve to act as a crush tube so ill just let it ride on the 1/4'' bolt,(6mm?) I may drill and tape bushing (bush? LOL) tubes for a grease zirk
Here's with bushing installed. Went in alittle easy, if the bushing is spinning in tube, I may have to add some welds inside for grip. I saw someone (don't remember who, sorry) but they welded round bar stock on the front for stregth, I didn't like the look of that, and thought this would look better.....now I'm thinking the best way would be either add the plate or bar to back of pedals, leaving a slim profile in front.. of course it would need notched for clevis/cable clearance that way. I will quote Jack from Kinetic Vehicles, (who makes cast aluminum ones for 30/each, only 3hr drive from me!) When he said: "I'm not much of a bling guy, and its dark down there in the drivers footwell, so I don't much car!" Sorry for quoting you Jack, if your on here!
Old 4th January 2012, 06:04 PM
Thank you for comments and concerns, sorry I failed to mention I've been converting everything to SAE, and using 1/8" plate and will use 3/16" for brake pedal. (3mm and 5mm). As I mentioned before, I HAVE reinforced my pedals, As I figured with some of these nightmare stories of bent pedals, and since it would melt bushings if I decided to do it later. I'm not going to test for strength, but I know I got good enough penetration, that they will be strong enough for even my "frantic clutch kicks"!
Here's the "spine" of 1/8" plate I welded down the outside of each pedal, sorry for 5mp droid pics!
IIRC the "height" of these plates was approx. 3/8" to 7/16". And length of 5" on clutch and 5 3/4" on gas(please don't ask to convert) why can't I find a metric tape measure?
Old 4th January 2012, 06:11 PM
Here they are painted:
Gloss black sure makes those "gorilla welds" look better!
Oh, and where gloves when grinding, so you don't "clean your cuticles" with a grinder wheel!
Or maybe I'm flipping off whoever said my welds "looked like shite"! Lol
