Old 6th January 2012, 06:06 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
I've also got the DOHC and have just gone through all of this and although it did take me a fair while it is wasn't massively difficult. I think I'm left with 3 relays and a couple of fuses, have you got the anti theft module as theres that to get around as well. Overall its taken me a couple of weekends to get it all done.
Old 6th January 2012, 06:16 PM
rapidtornado's Avatar
did you draw up a wiring diagram or just work it as you went along?
Old 6th January 2012, 06:33 PM
If your not using the body loom then there should be no need to worry about..
I guess I should really do a mini diagram of the plugs.
Perhaps over the weekend I will sort that out.
Old 6th January 2012, 07:03 PM
Luke2842's Avatar
I just worked my way through it using the Haynes wiring diagrams, as soon as you start removing parts of it it wont look like such a massive job. Have been following your thread on how to modify the inlet manifold and has worked really well.. thanks!
TT I have got rid of the anti theft module after hearing how to bypass it.
Old 6th January 2012, 07:11 PM
ahhh that would be ace... you could bag some beer tokens for that if/when I see you at Stoneleigh
Old 10th January 2012, 03:37 PM
brainbug007's Avatar
From what I understand you only really need to run a cat if your donor was made after august 1995? I used my donor loom which also had an ECU and it didn't take me long to strip down all the junk I didn't need and then shorten the ones that where too long. The longest part of of the job was picking all the tape off!
