Old 10th January 2012, 12:20 PM
Originally Posted by Powler View Post
Hi,
I hope this has an obvoius answer. What did anyone use to get the rear fog light to be vertical. It seems a triangular spacer will do, but I can't find any.
Any ideas ? I'm having a thicker day than normal !
Peter
Look at the photo at the bottom of this build diary.
http://tigeravonbuilddiary.blogspot.com/
Old 11th January 2012, 06:50 PM
a spacer can be made from bodyfiller and a make shift diy mould.
some people have even taken tape and set the lamp at the angle wanted and filled the void with body filler then sanded to get a good finish.
other ideas have been short angled bits of tube of some form or making steel or alloy bespoke mounts.
iirc the fog must be pointing directly backward or squarely to the rear in iva book
Old 11th January 2012, 07:29 PM
Peter-C Peter-C is offline
I've found some offcuts of what looks like square drainpipe. I cut it at an angle and it doesn't look too bad, I'll post a picture later.
Old 12th January 2012, 12:15 PM
Pictures of bracket
Old 13th January 2012, 08:56 AM
axle's Avatar
axle axle is offline
Thumbs up Thanks
Hi all
Can I just say thank you to all of you, I was just about to fit the lights on my car and was slightly puzzled on these matters, but you cleared it all for me.
Thanks again Axle
