Who are you trying to buy from?
"There are no secrets to success. It is the result of preparation, hard work, and learning from failure." "The road to success is always under construction" Michael Photo Albums Build Thread Donor: 1.6 Jap import MX-5 Chassis: Based upon Saturn MX-5 guide Official start date: TBC Build cost to date: £400 profit from donor sales
Don't know about the 25.4mm, but here, 19mm were not available either, and more expensive if I wanted to order them, so I used 20mm instead. Not a big deal for the bracing tubes, just the trans. tunnel is 2mm narrower, but it is not a problem.
Hope this help. Sylvain
ASD?
they should have all that in stock, I used to use the Exeter branch for most of my steel, until Dyfeds moved to within 5 miles of my unit.TK
Innovation not Imitation!
if you dont have a bandsaw/cut off tool that can cut accurate angles why not just get a "flat pack" set of pre cut tubes as i did
saves so much time and mess with no misstakes of bits cut too long/short. |
. i think i have a fetish for tools lolAs for a flat pack chassis kit, i suppose i like the challenge of doing it myself from scratch and don't mind too much the bit extra time it will take to cut up the steel. Just to be clear aswell this decision in no way takes into account the extra cost (which is marginal for all the good hard work the guys put into their great chassis packs and the tools/equipment they have invested in) My decision i suppose was based on challenging myself and self gratification . Well that and gives me an excuse to buy more tools.
Sorry to hijack but what sort of steel am i looking for?
My local stockist says they have 25 mm erw in semi bright steel but not in mild. and also what is black steel? Thanks |
you want semi bright erw its much nicer to work with , Hot Rolled Section is known as black because of the layer of scale that is caused by high temp forming.
As i side note, they said they would give me a discount if i simply create an account with them. Straight off this knocks 25% off delivery cost ![]()
