Old 24th January 2012, 08:08 AM
snapper snapper is offline
They'll spin when you come to take them off.
Riv nuts work well
As tanks are either thin steel or thin soft ally a load spreading collar on top of the sender spreads the clamping force evenly.
Sealant is not usually needed but if you do it has to be petrol resistant.
Sikaflex or Tigerseal is not and will drop into your tank and block up pipes, filters and pumps.
Gues how I know that?
Old 24th January 2012, 10:03 AM
Riv nuts work well
If you are refering to my method then it is obvious to undo them the same way as they were tightened therefor they would not spin
Old 29th January 2012, 12:54 PM
tex tex is offline
you need to use nitrile rubber to make a gasket from a gasket supplier - there will be one local to you in the yellow pages. only nitrile rubber is truly petrol proof and not resistant.
the fixings - use countersunk rivnuts - using normal rivnuts leaves the head proud which gets in the way of the face to which you want a seal. the countersunk ones sit flush M6 will do fine with stainless bolts. make sure that all seals mating faces have very very clean faces with no deep scratches - petrol will find a way along it sooner or later.
but please do not use any sealant - it will come loose and drop in the tank - then block your fuel lines and filters - usually while your out..
Old 29th January 2012, 07:08 PM
mark mark is offline
I welded a piece of 3mm on the top of the tank where the sender goes and drilled and tapped it
