Old 15th February 2012, 09:50 PM
Hi there,
I believe the rear upright bracket needs to be 10mm as I made the mistake of drilling 12mm holes and then filling them up and re-drilling them , unless you want to drill out your bushes to 12mm. (which I believe can be a bugger) . Also (I know this because I measuered them today) the bottom upright holes on the MX5 are 14mm.. 12mm bolts will have too much play.
Regards Johno...
Old 16th February 2012, 09:47 AM
andysredmini andysredmini is offline
Thanks Nathan, thats a big help.
Johno, thanks for the hole sizes. they tie in with the 3d cad model of the uprights i found on the web. I wasn't sure how accurate the model was but it looks as though it is spot on. it also corresponds with the first post on this thread http://www.haynes.co.uk/forums/showt...light=uprights
Old 16th February 2012, 08:09 PM
Hi,
Where did you find the rear upright drawing..... Iv'e looked and all I could find was a solid works step file.... If its a dwg file any chance you could send me the link or send me an attachment of the file...plz..
I'm using Autocad 2011...
Should get a drawing to you this weekend of the tank if that's ok.
Old 17th February 2012, 12:57 AM
It's the step file I downloaded. I can convert it to a dwg for you no problems.
Glad to help after your offer of the tank drawings.
I'll do all the views and send you the drawing. Just let me know your email.
I have some other parts too if you want them?,like the front spindles and ball joints, I got them from here http://locostcadfiles.wikispaces.com/
If there are any others you want I'll convert those too just let me know.
If you know of any other sources of 3d models I would be interested in seeing them. Im trying to model as much of the car on the computer so I have a better understanding of it to make the most of the limited time I can spend working on the real thing.
Andy
Old 17th February 2012, 03:29 PM
Originally Posted by Johno View Post
Hi there,
Agreed with Johno on this one - the upper rear bolts are M10, and 12mm holes are too big.
I may have found a solution that doesn't involve reworking my wishbones, or drilling out my bushes though.
I've just ordered some polybushes for the rear uprights from Strongflex, and they've agreed to supply the crush tubes with a 12mm hole, rather than the standard 10mm
I was going to replace them at some point anyway as it seems wrong leaving them as 20 year old rubber when the rest of the car is polybushed!
