Old 18th March 2012, 09:56 PM
Have you got the driveshafts on the correct sides?
I think one might be longer than the other.
Old 18th March 2012, 10:16 PM
I thought that but I couldn't get the driveshaft out of the passenger side hub so it has to be the correct one! It's weird! Hmm my diff has push fit driveshafts maybe there is some sort of difference about them that may require a slightly different mounting of the diff. I've scrutinised the frame, it's a few mm out here and there but not enough to cause this surely??
Old 18th March 2012, 11:10 PM
Do your driveshafts sit exactly in a straight line. My driveshafts angle forwards very slightly.
Old 19th March 2012, 01:31 PM
Sorry missed this, yes they angle forwards.
Old 19th March 2012, 06:31 PM
Hi Chris,
Thats strange one side being longer than the other...
My friend at work has the same diff with push in splines but we hadn't noticed they were different. I will have a look in the morning and see if we can mount his rear suspension and diff. If you do need new rear tops just let me know as I still have pipe left over.
Old 19th March 2012, 09:17 PM
Well there you go. Never seen that before! Actually something similar happened 20 years ago with my old Talbot Alpine but I can't even remember what, something to do with the dished washer, I digress...
A nice picture earlier today of my dog with the car in the background.
Thanks for the reply John and the offer, nice to know those upper wishbones are available if I find the car is crabbing when it's finished. :-)
How much would they be out of curiosity?
Old 19th March 2012, 09:20 PM
Oh BTW the car now has a square even back end.
Old 19th March 2012, 09:22 PM
Hi Chris,
As a fellow MX5 builder just cost of material and one day I might need a favour...lol.
Glad to know you got it sorted...
Ok just been out and measured the driveshafts and the passenger-side is 15mm longer than the driver-side the diff is mounted centrally in the vehicle so this would cause the issue I'm seeing. Can someone explain to me why one driveshaft is longer than the other. The diff also mounted centrally in the mx5 subframe as well so why the different lengths?
Old 18th March 2012, 11:15 PM
I think the output flange on the dif is longer on one side than the other.
