Old 18th March 2012, 10:51 PM
Originally Posted by Johno View Post
Hi all,
Well it's been some time since I've updated my build so had a chance today to take some photos.
Came up against a little problem as I made my bottom wishbones a little too long for the MX5 build from Saturn. As I had already finished and painted my wishbones I was a little reluctant to cut them up, so I decided to design my own top adjustable wishbones and make them easier to adjust on the car in situ.
Hopefully this will cure the problem but if anybody can see a problem please let me know.
Here's a photo....
Well got more to come but will update when I get time....
How much would you charge to make me a set of them? I've kind of hit a similar issue.
Basically I could only fit the rear pass side hub to the wishbones by putting about 10˚ of camber into it. Seems the driveshaft (halfshaft) is pushing the the hub too far out. also noticed that when lifting the hub it was stopped from travelling up by the driveshaft which then bounced the other hub up so something is not right. Seems I may need to think about moving the diff slightly. Took loads of measurements to see where I went wrong but can't real account for this issue using measurements alone!
http://www.haynes.co.uk/forums/showt...1417#post71417
EDIT: It's ok I found out what the issue was this morning.
Old 2nd April 2012, 09:36 PM
Well been spending a bit of time on the build but not as much as I wished (Simon)....LOL
I was considering changing my diff mount with thinking how can I incoporate a second rubber mount with what I have already fabricated. I wasn't happy about a 10mm rubber mount holding the diff in place on a top mounted bracket. Then I read Nathans report on his test drive so that motivated me to sort it out.
Had a play around with what I already have and came up with this...
Seems more robust just a bugger to get in with it being a welded bracket to bolt to the top and bottom of the diff the same as the original frame.
Also Nathan came down Sunday and delivered Lukes body kit....How about that for customer service....... Luke now a happy bunny...
Damm nice fellow just doesn't speak proper Lincolnshre English....LOL
Luke let me borrow his shocks and here's part of the result.
Old 2nd April 2012, 11:08 PM
Looks like a good solution. I like the way you have used the land mounts top and bottom, so one will always be in compression.
Old 4th April 2012, 08:01 PM
Well I hope so Chris, I guess only time and millage will tell...
Looking forward to working on the car this weekend with my friends who'll be working on their cars as well so hopefully we should have some piccy's to post next week.
Luke's keen to get his bodykit on now so any advice about how to fit it would be most appreciated.
He's opted for an unfinished kit from NTS which he plans to paint in a metallic colour after mock fitting all the panels.
Well this will be my last post for berfore Easter so I would like to wish everybody a happy "EASTER" break.,,,,,
Bye for now ......Johno
Old 7th April 2012, 09:07 PM
OK I spent some time on the car the last couple of days and got a few things done.
Most of my wishbones were removed from the bubble wrap today and found a new home..... None of the bolts are the right size or tightened so need to order them this week but you get the picture...
I know at the minute it's a sore point but I managed to mount my diff with it's bracketry and I'm pretty pleased with it. I managed to make a brace between the diff mount arms yesterday out of 3mm pressed steel without lowering the diff. I basically made a bracing strut of some description. It has the added benefit of contacting the rubber bush on top of the diff arm as the insert protrudes about 3mm anyway.
I countersunk the bolts in the plate so they did not interefere with the rubber on top of the diff.
Simon got a lot done on his car this week with the rear end being all mocked up and just waiting for the front bits and pieces before he can have a rolling chassis.
Out of couriosty we tried Lukes bonnet on Simons car to see if the air inlet would clear which it did with some room...pheewwwww.(thanks SKOV)
Ok pictures speek louder than words so I have updated my Photobucket tonight with the piccy's I've taken today.
http://s1199.photobucket.com/albums/...1/MX5%20Build/
Well have a good weekend Johno
Old 7th April 2012, 10:44 PM
Eternal Eternal is offline
Great work!
Love the Speedglas 9100 welding helmet. I have one too fantastic bits of kit!
Skyline Roadster
Old 8th April 2012, 06:58 AM
Hi Alex,
Yeah there great helmets. I only use it for TIG welding though as I don't want to bugger it up with spatter....
Old 8th April 2012, 11:39 AM
http://i1199.photobucket.com/albums/...3032012044.jpg
Not so sure about that top wishbone. That piece of studding has got shear in every plane and might fail. It would be better to adjust it on the inner bushes and keep the itegrity and strength of the original design on the outer joints. At the end of the day that studding will be getting hammered over every bump and hammered under acceleration + braking. Just thoughts. Think Toblerone
Old 8th April 2012, 06:11 PM
Haha those helmets are there to be used!
See!
Skyline Roadster
Old 8th April 2012, 07:03 PM
Thanks Robo,
Gonna re-think top wishbone but would still like to keep it adjustable.
Do you think it's to weak solely because of the threaded rod? I was planning to change it with a machined part with threads both ends and a majority of the body inside the bush just machined to suit the insert with a close fit.
I've used this setup for now just to determine my rear geometry so still playing with it. Missus won't let me have shocks yet....
I know Westfield and others fit top adjusters with Aluminium inserts and have had failures and I believe Ash G had the same problem so hoping this would be stronger.
Thanks for your advice Johno
