Old 20th March 2012, 08:57 PM
Jimmyd Jimmyd is offline
Default Clutch Cable Adjustment
Forum knowledge required!!
How tight do you adjust a clutch cable? Do you want the fork pulled up to the point that when released the release bearing is still in contact with the cover or not? Is it the case of pedal travel v's premature wear on the release bearing?
J
Old 20th March 2012, 11:41 PM
allterrain's Avatar
allterrain allterrain is offline
Adjust so that clutch pedal has about 1/4 inch travel before thrust bearing contacts pressue plate .Cheers Brendan
Old 21st March 2012, 07:33 AM
Thanks!!
J
