![]() Thanks Kev, I think you totally understood the question in spite of my approximate English
![]() Do you or somebody else know where I could purchase the extended steering shaft ? Thanks. Sylvain
![]() Your english is fine mate ....I have never heard of anyone buying a shaft, although some have bought THAT shaft from RD and extended it to fit back up to the steering column joint at the bulkhead.....this is one of the jobs I am due to do and I think the above is the way I will be going, but I'm sure some one will come on here and either say the same or explain how they did it.
kev |
![]() Sylvain, here's mine. http://imgur.com/a/w1QR3
I can put it on and off without unbolting the upper part of the column by sliding up the triangular shaft before connecting the splines at the rack. My extension is ~54cm long, and the shaft inserts into it by ~6 cm at each side. So the total length of extension needed is ~42 cm.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. Last edited by alga : 3rd April 2012 at 03:41 PM. |
![]() Thank you guys, and thanks to Alga for the pictures and specs. I guess I will have to make it myself. I'll check if I can use the donor car shaft when I get it (Sierra) before buying the one from RD.
Kev, could you keep me updated about the way you'll do it ? Thank you. Sylvain
![]() no probs will do
![]() what wall thickness and internal radius have people used for their extensions?
Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501 |
![]() I'm not sure what the internal radius of mine was but I'm fairly certain it was something like 25.4mm OD with a 3mm wall thickness.
