Old 3rd April 2012, 06:32 PM
Thank you guys, and thanks to Alga for the pictures and specs. I guess I will have to make it myself. I'll check if I can use the donor car shaft when I get it (Sierra) before buying the one from RD.
Kev, could you keep me updated about the way you'll do it ?
Thank you.
Sylvain
Old 3rd April 2012, 06:48 PM
no probs will do
Old 11th April 2012, 01:20 PM
MikeB MikeB is offline
what wall thickness and internal radius have people used for their extensions?
Old 11th April 2012, 02:20 PM
brainbug007's Avatar
I'm not sure what the internal radius of mine was but I'm fairly certain it was something like 25.4mm OD with a 3mm wall thickness.
Old 11th April 2012, 02:32 PM
Westfield uk do one which looks quite long although no specs are given and it does look like a normal splined shaft which has been extended with a piece of thick walled tube.Nice price also
Heres the link for the rich amongst you
http://retweeter.co.uk/magento/index...ng-column.html
Old 13th April 2012, 10:16 PM
Or car builder solution sells the extension tube by the inch.
http://www.cbsonline.co.uk/product/C...l_Tube_CDS2064
Old 2nd May 2012, 10:31 AM
Hi Sylvain....promised I would let you know how I did my steering shaft, well here you go
http://www.haynes.co.uk/forums/showt...t=4493&page=16
