Old 4th April 2012, 09:42 AM
i found chassis black over isopon zinc 182 primer works real well as the primer has etch qualitys and chassis black is pritty chip resistent (i have bashed my chassis about a fair bit in my build)
2l of each will be plenty if your spraying and use celulose thinner
cheap and easy to use
2k need air feed masks btw as it has isocynate in it you dont want that in your lungs or on your skin!
