Old 26th March 2012, 10:47 AM
Eternal Eternal is offline
Smart way to mount the front hoop but also add a bit of bracing to the chassis. Somtimes i supprise myself!
Skyline Roadster
Old 1st April 2012, 06:55 PM
Loads of progress today.
Headlights fitted,
Roll cage harness cross bar fitted.
Intercooler fitted
Prop shaft cage built (by friend) this splits in half to allow you to drop the shaft out.
Quick question.... i will be running the wiring loom and brake+fuel lines on opposite sides but do they have to be one on the bottom and one on the top?
Skyline Roadster
Old 1st April 2012, 08:20 PM
There has to be separation between the wiring loom and the fuel lines but otherwise there are no other specific rules as far as I know.
Old 1st April 2012, 09:46 PM
Cool so running them both along the top of the tunnel will be fine as long as its on opposite sides,
Skyline Roadster
Old 1st April 2012, 10:15 PM
Yeh that will be fine
Old 1st April 2012, 10:40 PM
Just need a radiator now before i can start to strip down and paint the chassis.
Skyline Roadster
Old 5th April 2012, 09:09 PM
Expect alot of progress over the long weekend! with any luck should get the column connected to the wheels. Rear cage finished. and radiator installed. Oh and maby the floor welded on!
VW GOLF MK2 16V (NOT 8V! as it is too long) HIGH FLOW ALLOY RACE RADIATOR 1.6L 1.8L GTI
http://www.ebay.co.uk/itm/1808329364... 4.m1497.l2649
Skyline Roadster
Old 5th April 2012, 10:10 PM
Oh also found a place and bought some 2mm steel for the floor and also a sheet of 2.5mm steel. Both sheets 2m x 1m for 30 quid each. Not bad really! I'm VERY tempted to use the 2.5mm for the floor.
Can any of you guys advise as to the best way to weld it in without having loads of distortion?
Skyline Roadster
Old 8th April 2012, 06:10 PM
Big thanks for my friends help today. Came up with some fantastic ideas on how to fix my inlet manifold problem. Expect some pics soon!
Skyline Roadster
Old 8th April 2012, 06:26 PM
Skyline Roadster
