Old 16th April 2012, 06:53 PM
misty misty is offline
meant to say also that on the solenoid there are 2 pillars and 2 spade terms can someone tell me what these are for please the large one is for the batt cable and the alt cable
Old 16th April 2012, 06:56 PM
Where did the engine come from? what connections are on the DIZZY?
can you get a pic of the solenoid?
Old 16th April 2012, 06:58 PM
If the engine has points then there should be a condensor unit on the outside of the dizzy and a wire , this goes to the coil -VE.
Old 16th April 2012, 07:06 PM
great info will get pics tomorrow in daylight many thanks
Old 17th April 2012, 11:41 AM
Got It All Sorted
Many Thanks To All
Old 16th April 2012, 10:11 PM
ok starter solonoid will have 2 big studs 1 in for the fat + cable from bat and one out that should still be conected to a short link to the motor.
then there is a smaller stud or terminal that works the solonoid its possible the extra one is linked to this
