Old 16th April 2012, 10:17 PM
rpjg1975 rpjg1975 is offline
Personally I had been considering this since my build started. I am going for a windscreen purely for those reasons, keep a little more of the wildlife out of my hair and teeth. I bought an extremely cheap locost screen off ebay and am in the process of modifying it to make it look right. Is a bit too narrow width wise and tall hightwise at the moment. Not sure at the moment whether to bother with wipers etc as it will be removes and retro fitted after iva to eliminate all the usual wiper, demister etc issues.
I'm sure I will not be the only member with an opinion so you will have plenty of other comments to fan the flames of the kitchen debate
Russ
Old 16th April 2012, 10:27 PM
MrsVmax MrsVmax is offline
Red face
Russ
kinda lost me with the technical details - but wipers are a must - gotta be able to see - and unless i am mistaken crash helmets dont have wipers - dont get me started on having pop up umbrellas for when it rains..... VMax goes potty when i start that, er.... discussion ...um
Car Builders Widow and now Composite Widow - and clearly a faster Driver
Old 16th April 2012, 10:32 PM
Usual thing is if u put screen on before iva I believe u must have demister, washers and wipers. I am thinking if I just use a screen but nothing else due to pretty low mileage I may get away with just cleaning screen occasionally. If not then probably make provision to fit something like landrover wipers or something like that. Shouldn't be that difficult either way......he says with fingers crossed!
Old 16th April 2012, 10:34 PM
well as a biker i have riden meny miles in all sorts of rain and its not to much of an issue
the faster you go the drips get pushed out to the sides by the wind as the visor is curved not flat like a windscreen
Old 16th April 2012, 10:43 PM
Selfishly, i just dont want hair stuck to my lip gloss - I was kinda thinking more "chitty chitty bang bang" than "torque" (google it - its a very good bike film) btw i would love to ride a bike but i cannot balance on my two feet let alone two wheels - and all that hand and foot cor-ordination jez too much for my little mind - i cant walk and wave at the same time without falling over some ant in my path sadly no joke
Old 16th April 2012, 10:35 PM
Crash helmet visors shed water nicely and keep fairly clear .They'll cause a lot less drag than a big wind anchor stuck on top of the car.Mind you with the size of some of the engines planned on here its not going to make a whole heap of difference
Old 16th April 2012, 10:48 PM
Crash helmet = bad hair shallow maybe but true, also the water has to go somewhere - usually down one's neck on in one's lap - whereas windscreen creates a magical shell to keep me dry(ish)
ANYWAY my sunglasses wont fit inside my Shuberth
