  #34
Old 17th April 2012, 08:45 AM
After this was made I came across a small problem in that you can not mount the seat belt top mounts to it, if you weld threaded bosses in to the tube you can't get the bolts in. The belts would have to go on the rear suspension cage and just lay over the bottom bar. This was made in 42x3mm it is not 100% matched side to side due to the home made bender we have and it is bloody heavy, how ever I think you would struggle to damage it much more than removing the paint in the event of putting the car shiny side down.
I'd ask these guys to bend it up for you.
http://www.ebay.co.uk/itm/Custom-mad...em4ab3d7 9cc8
