|   1mm is too thin, 1.5mm is plenty thick for these parts, 3mm is just overkill. TK
				__________________ Innovation not Imitation! |
|   Anything in that area will give a little added protection if overengineered.
				__________________ Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
|   Quote:
 Plus 1, with all the gear changing/clutch presses & hard braking the car will no doubt be doing then I,d rather have a pedal box support plate that WON,T flex. Plus 2, its also a cost saving if a builder decides to cut their own CP plates....saves buying different thicknesses of steel plate....I bought a 4ft x 4ft sheet of 3mm plate for £30 & cut all my CP plates from it & still have plenty left for whenever I need some steel for other projects..... but then again I,m a tight git     cheers andy |
|   Andy, Regards to all of the plating steel, my father can bring it home from work. F.O.C.   Will have to buy all the tubing though but that's not so bad! Just trying to work out how much I am going to need of what sizes. Don't happen to know do you? Could add up all the length's in the book but thought someone might know!... |
|   42m of 25x25 and 18m(ish) of 19x19 I think from memory. |
|   Nick, seriously, this question is being asked and answered in the forum about once two months!  Do a little search! http://www.haynes.co.uk/forums/showthread.php?t=6263 http://www.haynes.co.uk/forums/showthread.php?t=6553 http://www.haynes.co.uk/forums/showthread.php?t=6377 You asked it less than 10 days ago, and I answered it! http://www.haynes.co.uk/forums/showthread.php?p=72201 Chassis expert HandyAndy answered it many times, too: http://www.haynes.co.uk/forums/showp...56&postcount=3 http://www.haynes.co.uk/forums/showp...9&postcount=44 http://www.haynes.co.uk/forums/showt...mtrs#post46733
				__________________ Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
|   The word is "carefull " Andy not tight...........
			#18
|   No, he's tight.....      TK
			#19
|   Any give in that area would possibly affect brake pedal effort and therefore brake effort/force. Not good for IVA. Hence the squeak............
			#20
