Old 22nd April 2012, 08:44 AM
misty misty is offline
Default Height Off The Gound
Hi all
I Have 205x40x17 wheels on the car and was wondering should i have bigger bigger on as the car is sitting approx 65mm off the floor ,I thought i had read somewhere the car should be approx 100 mm off the floor ,any advice please
Old 22nd April 2012, 09:50 AM
That does sound a tad low!
Have you got the correct length shocks?
If so you might want to wind up the pre-load.
Old 22nd April 2012, 10:41 AM
TSM Locost's Avatar
Default Ground clearence.
Most people with 7 replica's use 125mm front, 150mm rear for road use = chassis to ground.
Be Lucky, Mike.
