  #18
Old 25th April 2012, 06:57 PM
nickharding nickharding is offline
Bumped into a problem already.
Looking at this diagram..
You can see that RS15 which is 19x19 sits against the suspension mounting bracket. After measuring it out, I found that this is not the case and don't understand where I have gone wrong? .. Following the diagram I checked that RS15 was 19x19. Next after following the diagram to see which side RS15 went on, I measured 19mm down the one side, this has been marked with a scriber as you can see in the pic below. These are accurate measurements.
Next I used the diagram at the top to place a pop mark to show the centre of the bracket. This is also accurate as I have checked many times.
I then checked the spec of the suspension mounting brackets and saw that they were 40mm wide. So from the pop mark i measured 20 both sides. As you can see from the close up of the ruler, there is a gap between 0 and the rs15 mark.
Does the bracket actually sit against RS15? Or is it just a misleading diagram?
Cheers.
