Old 1st May 2012, 05:43 PM
Started work on my steering extension ....was going to use an old strimmer shaft but decided its wall was too thin, so then decided to use some of the left over seamless tube from making the wishbones....19mm thick walled....perfect for the job also decided to use the original uj's as there was nothing wrong with them, no perishing in the rubber one and no play in the upper one. Cut the awfull triangular thing off the upper bottom part and turned it down to fit inside the extension tube, and ground down the triangle on the upper one to fit the tube then welded the bottom one up but left the upper one as I need to sort out the bearing support I intend to make.
heres the piccies
