Old 26th April 2012, 12:10 AM
nickharding nickharding is offline
Thanks again mate.
You certainly are "HandyAndy".
All The Best.
Progress soon...........
Old 1st May 2012, 11:08 PM
Small update..
Haven't been able to make much progress over the last week. This is because I have been extremely busy with work, also had to do a gearbox change on my friends car. Hoping that over the next week I can start to finish off the plates and look at getting the steel ordered!
Spent a couple of hours yesterday and managed to complete CP18 x4 (seat mounts) and get the nuts welded into place too. Weld's are not completely clean as the nuts I welded on had some kind of Zinc coating on them to stop them rusting. I ground these off before i welded and also buzzed over the plate before welding so i have 2 clean faces, but i think there must be a small reaction with the metal in the nuts to the metal of the plate. Either way it aint too messy and wont be falling off.
Pic...
Also after making a thread called "Chassis Nut and Bolt List" i managed to find out the different sizes and lengths of the nuts, bolts and washers for the suspension and the diff.
My father was able to bring these home from work with him tonight, i only gave the list to him last night!
There is more than enough plus plenty of spares.. Also got him to bring me home some more grinder disks.
In the pic above is...
- 10 grinder disks
- 32 M12 8.8 bolts
- 54 nylock M12 nuts
- 78 M12 Crimp nuts
- 211 M12 washers
- 20 M10 normal nuts
- 20 M10 Crimp nuts!
Just need to order the 2 x diff bolts, 2 x upright bolts, and the head/nut caps now and I should have all the bolts I need.
I noticed after reading IVA that you need to use nylock nuts to stop them vibrating loose. Well these are great but can only be used once or they end up loose, also the nylon can melt in temp conditions and also come loose. Was hoping to use these crimp nuts. The last few threads in the nut has a slightly smaller pitch making it like a crimp, so cannot come undone form vibration and can be used as many times as possible. Would this pass IVA?
They are Zinc coated so are rust resistant the same as stainless ones.
Cheers.
Old 2nd May 2012, 08:22 PM
No offence meant or intended but it looks as though you have fully threaded bolts on your picture,for suspension and shocker applications and other stressed parts partially threaded bolts would give more security,if you think of every root of the thread as a failure point you can see what I am getting at.
Old 2nd May 2012, 09:50 PM
gtipping gtipping is offline
What I am seeing in the picture are Set Screws - these are threaded their whole length. Bolts are similar but are not threaded the whole length. It is important when ordering supplies that you specify the correct item as flyerncle says a Set Screw will have inherent weakness when used in certain applications.
Old 4th May 2012, 10:05 AM
Thanks for your input guys. I will see what else i can find today. Will keep these bolts for other parts of the car.
Old 4th May 2012, 10:32 AM
From memory these are called k nuts and were originally for aerospace use.Personally i would use suggest using normal nuts when test fitting parts and then use the nylocs for the IVA as i dont know about the inspector being able to tell the difference,use the k nuts for manifolds etc.
Another thing to note also is your bolts need to be rated as 8.8 tensile strength and BZP bolts have a higher strength than the equivelent stainless ones.
Old 5th May 2012, 07:21 AM
Davey's Avatar
Davey Davey is offline
Exactly where does this idea that Nylocs are single use come from? I've been re-using nyloc nuts for 30 odd years and never known one to come loose. In the motor trade it is not normal practice to fit a new nyloc nut every time one is undone, we simply refit the old one.
D.
Old 6th May 2012, 11:32 AM
Thanks Guys.
Someone advised me to use shoulder bolts instead of set bolts, so got my father to bring me home what I needed.
60's and 80's. For the 70mm ones i will just have to cut 10mm thread off. Not a problem.
Pic..
Davey: I have just noticed that once they have been on and off a few times, they dont have such a tighter fit as when they were new.
Ozzy1: All bolts i use will be 8.8 tensile. Pic above
