Old 9th May 2012, 03:19 PM
Originally Posted by rpjg1975 View Post
Sorry andy, its the sensor I can't find, I just have the plug with my label on it. It actually looks like the same type of plug as the two connectors on the inlet manifold.
It's a type 9 gearbox and I am thinking similar, cant remember any others on it except from thw reversing light one...
The plug has 2 brown wires going to it if that helps at all?
Russ
Sorry Russ,
I meant to say the socket / connector that plugs into the so called sensor .
Ermmm...just thinking.....wouldn,t it be spooky if its the same plug/connection to what we found on the underside of my air filter housing last night?
I,m pretty certain that has 2 brown wires too.
maybe its the air filter sensor thingymebob
