#19
![]() For anyone looking to buy in the future for an mx-5 Saturn/NTS build requires....
Front 350-400lb 8" length 1.9" ID springs. I got some on ebay in black from JJC for about £50 inc vat the pair. Shocks can be either 13" open 8" closed with a 1 inch extension to the shock or as I have bought 14" open 9.5" closed I got mine from rallydesgin for £60 inc Vat each. Rear 200-250lb 7" length 1.9" ID springs. Again I got some on ebay in black from demontweaks for around £50 a pair. Shocks as advised by Nathan, should be 12" open 9" closed. I got Gaz again from rallydesign 12" open 8.5" closed. If you order from rallydesign you want to order. Universal bush eye top and bottom. 2x 140/095/B12 2x 120/085/B12 If you want bearing and not bush then it's R12 not B12. So the whole lot cost about £340-350 delivered inc a c-spanner for adjustment. If you don't mind yellow springs you can knock £35 off that price getting your springs from Nathan/NTS or rallydesign. Note that rallydesign don't do 400lb 8" 1.9ID springs only 350lb. If you don't want to take a chance and want to be sure you get exactly what is recommended then go to Nathan and get a full setup from him. I'm skint so I took my chances. HTH. Chris |
