Old 14th May 2012, 12:56 PM
Originally Posted by MikeB View Post
thanks dave, thats another option a m10/m14 hole on the inlet manifodl plate that's blocked off the old water feed.
Might try the brass adapter first though, I need to blank it off with something anyhow!
Kenlow used to supply an adjustable thermostat switch , you just poked it up the side of the top hose and did the clip up, job done. The small copper tube was so small it just moulded into the hose.
http://www.holden.co.uk/productImage...ic_080.253.jpg
Just thoughts.
