Old 27th May 2012, 04:09 PM
The standard cable drive speed is 1000 revs per mile. So, sounds like your sensor should give out 2500 pulses per mile if the tyre size is right.
Old 27th May 2012, 05:31 PM
rpjg1975 rpjg1975 is offline
Excellent, cheers albert, will give that a shot. I am running 195/60/R15 tyres. Nothing is easy is it?
Old 28th May 2012, 07:57 AM
when i was looking into speedo drive ratios it was a bit unclear what you actualy get
all sierras had diffrent wheel/tyre sizes, diff ratios and there is more than 1 type of cable drive in the back of the gearbox (type9).
i could not find out if all the dials are 1000rev/mile
there is more than 1 way to work it all out and im not upto date with the ford speedo pickups but didgitalspeedos one is 6pulce/rev and is reedswitch type.
you have to mesure around the wheel like you would your waist then work out how meny turns a wheel does in one mile then work out the wheel/cable drive ratio and work out how meny cable turns in one mile and how meny pulces your pickup has.
Old 29th May 2012, 07:55 PM
Tyre rolling radius is a bit smaller than the tyre overall radius. So I would pencil a mark on the tyre and on the floor, roll one revolution, mark again and measure. But theoretical calculations should be sufficient:
http://www.miata.net/garage/tirecalc.html
Old 15th June 2012, 11:31 PM
i was having a poke about in the garage yesterday
my prop>cable drive ratio is 3.5:1 and my doner should have had a 3.6 diff so wheel>cable is almost 1:1 if everything is orignal?
Old 16th June 2012, 10:11 AM
Brilliant, cheers. Not got any further on with this yet as got totally confused with everything!
