Old 19th May 2012, 07:51 AM
Tatey's Avatar
Tatey Tatey is offline
I have to say I wouldn't want to risk using a cracked flywheel, as when it goes it goes, and with already being cracked it is just a matter of time before the cracks grow long enough until fast fracture can occur.
Not really something you want to risk :
http://www.youtube.com/watch?v=0NYZV...eature=related
Old 5th June 2012, 03:16 PM
Default Reduction valve
When you installed the brake pressure reduction valve in your rear brake line what size of union was used on the input side? It seems a lot bigger than 10 x 1.
I was trying to work out which way around it went until I came across the question you had asked on the ma5da racing forum.
Old 5th June 2012, 03:50 PM
No idea what it is I'm afraid!
My local friendly garage had a dig through their pot of brake unions and found one the right size
Old 22nd June 2012, 11:19 PM
I think it must be time for an update!
Haven't had a huge amount of time to spend on the build for the last couple of months, but slowly managed to strip the engine down and replace the head.
Also swapped the scary cracked flywheel with a decent second hand one I picked up via mx5nutz.
The free engine stand I got from the tip came in handy!
Actually got a decent session in the garage for the first time in ages tonight, and managed to get the engine into the chassis:
The bonnet fits, which is nice!
Old 23rd June 2012, 07:53 AM
Good effort, just need to get it running now
Old 23rd June 2012, 08:52 AM
Thanks TT. Hopefully won't be too long before I get it running, just need to sort out the spaghetti under my scuttle
Old 23rd June 2012, 12:55 PM
Wow, your spaghetti looks super tidy compared to mine. I'm trying to use the Sierra fusebox, and it looks like a tangle of wires.
Old 23rd June 2012, 07:57 PM
Looking really good skov. I was looking at your photos. In the second album what is the blue cylinder shaped item. It looks like it is the last photo on there.
david
Old 23rd June 2012, 10:15 PM
david
Thanks David.
If you mean this, it's my fuel pump.
I'm currently figuring out where to stick it!
I think I'm going to do something similar to Alga here:
http://www.haynes.co.uk/forums/showthread.php?t=8197
Old 23rd June 2012, 10:38 PM
Are you not using the in tank mx5 one?
