Excellent - thanks Alga!
I discovered that the bracket used to mount a good old fashioned ignition coil is a perfect fit for these pumps, just mounted on a couple of bobbins.
Cheers Adrian |
Similar pump
Here is how I fitted mine. Petrol pipes not connected yet.![]() |
i have the same pump its a bosch copy you can buy expensive mounts or i have seen big p clips, exhaust clamps and all sorts of other things used to mount them up.
as said you want something to prevent the vibration/noise been amplified by what your mounting it to. if you have it plumbed up direct to tank then you need it mounted at the same level as the lowest point as thay dont self prime and running dry will damage the pump as its a roller style pump and needs the fuel to lube it. |
As above keep it as low as poss and fit a pre filter as they dont tolerate crap running through them.
Large end is usually inlet and small is pressure out,same with electric terminals or you may find it goes backwards.
Thanks all, I think I know what I'm doing now
