Old 24th June 2012, 06:49 PM
The three terminal one is for a 2-speed fan. I suspect it might not be ideal for a 1-speed fan application, as the trigger temperatures may be lower and higher than ideal for a single switch. I just bought a 2-terminal one. Mine is there mostly to plug the hole in the radiator, the ECU will control the radiator fan based on the temp sensor in the thermostat housing.
