Old 25th June 2012, 09:45 PM
Thanks guys,
Appreciate the nice comments. I had a play tonight with fitting a sort of cable fixing rail and got a bit carried away...
After I finished and thought about it I'm now not sure if this is acceptable.
I've "P Clipped" a solid piece of aluminium at intervals of 300mm or less (mostly 150 to 200mm) where I think I need my wiring to go.
I plan to run all my wiring in varying sizes of conduit and then cable tie it to the ally bar. I've seen pictures and videos of wiring cable tied to the box section on Westfields in conduit and loom tape so though this would be OK.
Should have asked the question on here first I guess....ggggrrrrr
Here are some photos to show you what I've done.
Oh I also managed to flare my fuel line ends tonight with a Sealey brake flaring tool. Seems to have done the job...
Any thoughts would be most appreciated.
