  #32
Old 8th July 2012, 07:38 PM
Default Electrical help required!
I've started trying to lay the loom over my car to identify some connectors that weren't labelled on my loom.
The bit I am really struggling with is the battery end. There positive terminal has 2 wires coming out. One of the has been cut and the other appears to go to the starter motor then to the fuse box. I cannot work out what the cut on is for. There is also another black and yellow wire ( which I am assuming is the negative but the connector looks like it could fasten inside of the positive terminal.
Here is a photo showing these? Any ideas ???
Also......
To the rear of the fuse box there are 2 wires. A white on that seems to com back from the alternator and a black one. They both have rings on the end. Where do these go?
