Old 9th July 2012, 09:42 PM
Default few of my bits up FS on locostbuilders
few of my bits up FS on locostbuilders if anyone is intersted
http://www.locostbuilders.co.uk/foru...php?tid=172271
http://www.locostbuilders.co.uk/foru...php?tid=172276
Old 10th July 2012, 02:04 PM
Deanno's Avatar
Deanno Deanno is offline
For some reason it will not let me see them?
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 10th July 2012, 07:04 PM
Hi Dean
Don't think you can view new for sale posts on LCB until they are 24hrs old if you are not signed up as a member & logged in.
Old 10th July 2012, 08:34 PM
Deanno's Avatar
I am logged in and all i get is this:
LocostBuilders is a FREE service, supported by sponsorship, a little advertising revenue, and YOUR DONATIONS!
I operate LocostBuilders in my spare time, with connectivity donated to the cause by my business, NetrinoUK. All donations, trader's subscriptions, and the little advertising revenue generated goes straight back into maintaining server hardware to ensure the site runs quickly and smoothly with a substantial amount of money coming from my own pocket - money that I would far rather spend on building my car!
If you would like to contribute towards the site's running costs you may do so using the Paypal link below. A single donation of £10 or more entitles you to an exclusive 'Contributor' message under your username to show all other users that you have made a donation. Also, if you are a new user, you can bypass the 7 day/10 posts requirement to post advertisments in the market place (providing you are not a trader of course!). Contributing to the site is entirely optional. When I started the site I made a promise to keep the site a free resource and will endeavour to keep this promise to the community for as long as is practically possible.
Old 10th July 2012, 08:45 PM
Unhappy Very odd
That's an odd one Dean
Here's a copy & paste of the adds
clearout zetec and sierra parts
i cant move in the garrage attic as i have too much handy stuff i have kept but no longer need so here goes
all parts are in exeter devon collect for free or pay for postage
resonable offers please
if you have any Q please u2u me
from 1.8 cvh sierra 1993 unless stated
alternator with 5v pully (new recon on doner when broken) working when removed
set of cvh engine mount brackets
set of pinto engine mount brackets
4x engine mounts (rubbers)
peddel box inc throttle and brake switch
cvh hybrid ign pack/unit inc plug
exhaust manifold short tube type from blacktop
complete cvh carb/inlet manifold with pipes stat etc in good working order for cfi convertion
zetec parts
1800 ecu inc plug (can be wired to run without pats)
silvertop throttle body inc tps and plug
silvertop idle valve (3hole type)
blacktop throttle body inc tps and plug
1800 cvh flywheel reamed to fit zetec crank with almost new clutch (complete)
for zetec/type9 conversion trigger wheel needed
for sale project zxr636 ITB's on zetec manifold
i have made a manifold for my ms2 injection build with some zxr636 that i no longer need
its a silvertop injector plate with injectors,plugs,pipes, fuel rail and reg included. i tigged some shaped thick wall alloy tubes to fit in a jig to it
with a set of kawasaki zxr636 throttle bodies(38mm) with the motor and 2nd set of butterflys removed and holes plugged.
i have kept all the injectors to go with them if you wish to run them along with all other bits and bobs i have that went with them and will re fit what i have.
tps is still there but i dont have the vac hoses in the pic any more i have lost them somewhere sorry
there is a set of blue fluro hoses but i think i should have gone down a size but thay may squash up with some clips
needs a bit of cleaning up inside but all the hard work is already done
here are some pics note there are no zx injectors shown but are included and its all just resting on a bit of box for postioning thats not a chassis rail.
the boddies will fit either way up (eg. upside down)
spent quiet a bit of time and money on thease and would like them to go to a good home and recoup some of my build funds
in exeter for free colection or pay P&P reasonable offers only please
u2u any Q's you may have
zetec to zx636 bodies
Description
Description
I don't expect the images will show though but I expect Baz will upload them to this thread when he gets a chance
Old 10th July 2012, 09:05 PM
Deanno's Avatar
Cheers Ronnie
Old 10th July 2012, 10:42 PM
thanks for sorting that ronnie
lcb will not let you view new FS posts if you have not donated and logged in but i have never had any issue when logged in if that helps.
im just looking for a few pennies for the buildfund from the odds and sodds befor i chuck it in for scrap
Old 11th July 2012, 12:59 AM
PorkChop PorkChop is offline
I've PM'd you a question or three about your ITBs Baz
