Old 12th July 2012, 09:59 AM
jps jps is offline
Sorry to ask - i know the car is gone now - but is the CVH engine as useable in the Haynes build as the Pinto? I guess the engine mounts will need shifting - but is the engine height an issue?
Old 12th July 2012, 04:14 PM
rpjg1975 rpjg1975 is offline
There are many builders including myself that have cvh engines fitted. The only issue that I am aware of heightwise is that you will have a k&n filter sticking through the bonnet unless you choose to run bike carbs
From memory I think the twinky engine is taller but there are still builders using them so not out of the question
I fabricated my own engine mounts so the engine sits lower in the chassis and I believe this is the norm also
Russ
Old 16th August 2012, 07:19 AM
jimmight jimmight is offline
Dont know about other areas but I had all the local pikey's offering to buy the shell when I have finished with it so should be worth 20 quid
I am satisfied completely from the impressive working of the website of Pass4sure for more information AccessData for more detail wikipedia you can also see about this site Amazon Best of luck.
