Old 20th July 2012, 12:24 PM
Default 'E' marks
I have just had a scour of the IVA manual with regards to lights and If I am not mistaken rear lights and indicators do not have to be E marked ....can anyone verfiy this or correct me if I am wrong.....the only mention is when it is a combined unit and the fog and rear are 100mm apart an E mark apparently confirms this.
Old 20th July 2012, 02:05 PM
As far as I can tell only the rear fog light needs to be e-marked (and the headlights if they are gas-discharge type).
Old 20th July 2012, 03:29 PM
brainbug007's Avatar
I think fog lights have to have an E(or e) AND an F(or f)?
Old 20th July 2012, 08:06 PM
From the manual:
All rear fog lamps must display an “e” or “E” mark with a “B” or “F”
Old 22nd July 2012, 11:54 AM
Big Vern Big Vern is offline
I must say that seems odd as it was a requirement of the SVA, I know'cos I failed. (small round lucas lamps - reason for failure lenses not E marked)
Wonder if I could get a refund on the retest fee?
Old 22nd July 2012, 12:15 PM
BV have a look at the current iva manual and tell me where it says all rear lights require E's....I will probably play safe but I am going to put front indicators on that are not e marked and take a set with e marks (to be safe), but I would say according to the manual you probably are entitled to a refund
Old 22nd July 2012, 08:50 PM
I've looked and connot find a reference to e marked lenses, like I said I wonder if I can get a refund on tjhat SVA retest I had to do
Old 22nd July 2012, 09:30 PM
Maybe it was a requirement for SVA, but has been dropped for IVA?
Old 23rd July 2012, 12:06 PM
That's how it seems. Though odd as E marked lights are a requirement for all other types of euro type approval.
Old 15th August 2012, 10:20 PM
tazzy5918 tazzy5918 is offline
So...in the end...do we need an E mark and if yes..where?
For exapmle... i m using LED indicators for rear with no marks-and the shape of them is almoust the same as Donkevoorth use.
As for the head lights i use some cases from a tractor..with the same shape an sizes as Caterham.
Will it be a problem?
