  #28
Old 28th July 2012, 07:14 PM
Originally Posted by K4KEV View Post
fancied doing something different to keep up my interest so I'm embarking on the task of making my own ally fuel tank.
I have always thought the book tank was way to small so at the expense of "boot" space I have decided to make my tank in a shape that utilises the area above the diff as well.....I have also decided on 3mm aluminium which might seem overkill but I believe that in a rear end collision it is far more likely to deform rather than rupture and that in its self should create a kind of crumple zone which adds further peace of mind it will have two internal baffles to keep "slosh" down to a minimum and either a sump or swirl pot in the base to cater for fuel injection, capacity is 57.5 litres might yet add a little more to the top to bring it up to 60 not sure yet
Going to do this in my usual methodical way which to to make a cardboard mock up and when I am satisfied with that I will make a template then a sheet metal folder to initiate the construction proper....so for now here is the mock up in cardboard ...it needs a wee bit of fettling yet
if any one is interested I might be making some more but they wont be cheap due to the amount of work involved and the fact that they are 3mm thick
Did you do much more on the long range tank Kev ?
