Old 7th August 2012, 10:37 PM
Plenty of 2.4's about.
Originally Posted by Dualist View Post
It's all in stainless.??
Once it's on the road check for cracks religiously, I was gonna build one out of stainless but got told it don't like shocks and will crack, not where the welds are but a few inches away from them, basically everywhere.
One of the guys I work with, his boss build a trailer out of stainless and went on a camping trip to France, even though it didn't have a big load on it (just his tent and some gear) the chassis of the trailer had cracked around tubes near the suspension mounts and ended up left on the side of the road as it couldn't be repaired, he had copied a mild steel version so though it would have been ok, obviously it deals with stresses in a different manner.
Stainless is ok providing that you use the right grade . hytens1200 or somthing like it is the way to go. i would like to think that the guy who built it has done the research but point taken and will check it out. TT how can I tell if its a 2.2 without pulling the head off. is it a stroke or an overbore?
Old 7th August 2012, 11:29 PM
it could be just the side panels as the expence of a full s/s chassis would be silly
as for 2.1+ pintos are thay stroked or are thay just over boared?
Old 7th August 2012, 11:59 PM
Stroked and bored
If done cheap they are crap, it takes a lot to get a good one built.
Old 8th August 2012, 12:23 AM
chrisponter chrisponter is offline
Sounds like weld decay, the chromium in the stainless steel reacts due to the heat of the welding process leaving a band of non-stainless steel around the weld, which then leads to cracks or corrosion. Depends which grade of stainless steel it is.
Old 11th August 2012, 10:43 PM
Ok you lot are right its odd ball. I stuck a tape over it and its 2" narrower than the haynes. But what is it?
Do ya naw wert i iz yit?
Old 11th August 2012, 10:54 PM
bob
Old 12th August 2012, 12:24 AM
They look like Indy front wishbones to me. And if I'm,not mistaken isn't the Indy 2 inches narrower than the Haynes? But that isn't an indy chassis LOL, who knows
Old 12th August 2012, 12:21 PM
Could be a Locost with Rorty IRS.
Old 12th August 2012, 08:24 PM
Wynand's Avatar
Wynand Wynand is offline
Im gonna be devils advocate here
If the chassis is the same width as the original book chassis (2 inches narrower than roadster) but 4 inches longer in length than the book one, it might just be a McSorley 400 chassis. The chassis construction point towards this.
The McSorley 442 & 442E are 4 inches longer and wider and 2 inches higher (albeit differently portioned between these two chassis) than the std book.
chassis.
Wishbones is not indicative of a specific design in many cases simply because many change these items for aesthetic or geometry reasons. In my case I modified the upper WB to add more positive caster and both bottom and lower WB are of my own design. Many others does the same all the time for whatever reasons they see fit.
Wynand
http://5psi.net
Old 16th August 2012, 11:34 AM
My money would be on it being either a McSorley or perhaps a modified Robin Hood chassis.
As far as I can make out those wishbones look identical to those on my MK Indy.
