Old 6th August 2012, 11:11 PM
Thanks guys, I did indeed have a big grin
I had a little bit of excitment just before that too. Ran the fuel pump to get the fuel rail pressurised in preperation, and it turned out one of my injectors wasn't seated properly, resulting in a petrol fountain!
Tried to make a start on the exhaust today, but the bearings went in my angry grinder... and shortly afterwards I managed to break my last jigsaw blade trying to cut an exit hole in my side panel
Old 8th August 2012, 12:02 AM
John,
On the fuel rail which of the fuel tubes is the input and which is the exit?
I was going to select the one with the small regulator as the exit. Hoping this is right. I was thinking that if yours started you must have had them the correct way around.
Old 8th August 2012, 06:52 AM
Hi David,
That's right - the one at the rear near the regulator is the exit. I went on mx5nutz and asked that very same question just to make sure!
Old 8th August 2012, 09:34 AM
Default Shiny!
Oooh, the postman has been kind today
Old 8th August 2012, 08:31 PM
Well that looks very nice indeed....
May I be cheeky and ask how much?
Really looks well made, what are the specs of it.
Once shes fitted first test drive looming......????????
Old 8th August 2012, 09:06 PM
It's a Simmi Performace stainless steel end can.
Handmade in the North of England apparently, so must be good! It does appear to be very nicely made.
Comes with a removable baffle too which might be handy for the IVA noise test
Here's the ebay listing:
http://www.ebay.co.uk/itm/250800426533?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
Still a fair way off the first test drive yet! Hopefully get time to drop the propshaft off for shortening this week, which'll get me one step closer.
Old 8th August 2012, 09:28 PM
motomaniac motomaniac is offline
bloody hell, simmi, hes just up the road from me.... did the removable baffle for my supermoto.... nice work he does...
Old 8th August 2012, 10:46 PM
The exhaust looks good and it comes from consent the home of the philleas fogg tortilla chip!
That's only about 10 miles from me so I may use one of those if it works well.
Old 9th August 2012, 01:04 AM
hes just outside if he hasnt moved, somewhere i think near stoney heap.... got mine done a few years ago, so he might have got bigger premises now...
Old 21st August 2012, 09:08 AM
My shortened propshaft turned up from Bailey Morris today.
Looks like they've done a great job, and have even painted it which I hadn't expected!
