if you can get the sierras full and empty restences you may be able to find a aftermarket sender
usualy there are a few common ranges my one is 30-190 ohm that is very common or there are little boxes that can convert senders or use pull up and pull down resisters but thats a bit of a mine field new gauge and sender packs are not that expensive and well worth a look |
