Old 11th September 2012, 07:21 PM
That picture looks familiar :-)
I wont bother changing it now, but i do wish I'd seen these things 6 months ago!
Old 11th September 2012, 08:16 PM
Turn the tee piece 90 deg to the right and fit the switch to face down.
Definate air trap the way it is.
Old 11th September 2012, 09:18 PM
I'll wait to see if it's a problem first.
I've already filled the system with fluid, so I don't fancy changing it unless I really have to!
Old 12th September 2012, 11:03 AM
If you have to open the system and change it,hold the pedal to the floor and it will stop it emptying all over.
We do it all the time when replacing the load of pipes we change with failing MOT's.
Old 12th September 2012, 08:50 PM
what he said or at 180 so switch is at the bottom
i do dislike having the brake res so low in the system if you get any leak above it,it can letair in and you louse braking if you have the res higher it will drip out fluid and show its ugly head and the level switch will warn befor brake loss
and it makes bleeding harder
