Old 15th September 2012, 12:18 PM
DaveyB DaveyB is offline
Default front uprights
Hi i recently purchased some front up rights and the bolt that clamps the mushroom insert in is missing any one know what size it is ?
Cheers,
DaveyB
Old 15th September 2012, 02:09 PM
M12x40 originally, but you want ~25 mm extra for the wing stay mount.
Update: grade 8.8 is OK, as it's what it was on Sierra.
Old 15th September 2012, 10:32 PM
Default Mushroom insert
Hi and thanks for the help, could you also tell me if the mushroom insert is actually clamped in that position being the only way it is held in place, sorry if this is a stupid question.
DaveyB
Old 16th September 2012, 08:46 AM
rpjg1975 rpjg1975 is offline
You also need a secondary fixing to please mr iva. normally a hole drilled and tapped with a bolt or grub screw fitted through upright into mushroom.......once you have it positioned correctly! i.e offset towards the front!
Old 16th September 2012, 09:44 AM
Thanks for the help are there any specific photos of this any where you could point me. Thanks again
DaveyB
