Old 19th September 2012, 11:48 AM
Ben_Copeland's Avatar
Bob, yes he's making fat boy seats too....
I've already given him maximum measurements from my chassis
Old 19th September 2012, 12:02 PM
DRCorsa DRCorsa is offline
Originally Posted by Ben_Copeland View Post
More pictures as promised.
Bit more exciting news on the horizon, which I'll put a new thread up for
It looks really great!
If you are at the place, could you please take a pics or two of the LHD dashboard? Thanks!
Old 19th September 2012, 07:21 PM
Well if you dont need an oil cooler hole, you can fit the number over the hole or you can use the original nosecone. It was made that way because people asked for it. You cant please everybody all the time unfortunately.
Old 20th September 2012, 09:04 AM
One question Ben.
How much is the internal height of the bonnet? I ask to see if my engine (BEC) will fit under it without the need to make a cut.
Old 20th September 2012, 09:28 AM
Carl Knight seems to have got an exemtion letter from the DVLA for his - have a look here:
http://www.haynes.co.uk/forums/showthread.php?t=7975
Is it not ok to stick a number on the nose cone like lots of other sports cars?
Old 20th September 2012, 09:59 AM
A number plate made up of stickers over the nose will not currently pass an MOT so it's a good job it only has to be there once a year then. A square lorry type plate with 50x 12mm holes drilled through the white section will.
Old 20th September 2012, 10:35 AM
Originally Posted by DRCorsa View Post
One question Ben.
Internal at the back it's 264mm at the front it's 203mm I would allow another 4mm for the thickness of fiberglass on the side panels on top of the metal rail.
Old 20th September 2012, 07:56 PM
Any piccies of the seats ??????
Old 20th September 2012, 07:58 PM
I'll ask for you.
